Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
so my borther in law bought this piece a crap 97 f150 with a 4.6 romeo in it, had a bad miss, turned out to be a burnt valve on the DS. got it fixed, still runs horrible.
checked the FPR and it holds vac. makes no difference vac. or not applied while running, egr holds vac, new plugs, new wires, changed every fuel injector with known good ones, still nothing, changed the egr solenoid and a couple of other sensors with good known working ones.
No codes, only an evap one, runs terrible, bad miss at idle, smooths out over 2k rpms, trys to die once you let off, unhooking several injectors while running does no change, a few do drop it down further. coil packs have nice blue spark.
fuel pressure is good and in spec.
we're lost on this thing, was told it's not even run if it was out of time, it's a single over head cam motor one over each head so 2 cams total, and has 2 coil packs, four cylinders on each pack.
any ideas? computer? oxygen sensors? timing?
