Need help on cleaning cowl
SubDominant
California
Keith
V1500
5.7L
Ok. I just removed my cowl to find this:
Vacuumed that out...
Removed the plastic grid and found this...
You get the idea. So I get rid of all the junk....
But now I need advice on making it **** and span! I want to spray it down with disinfectant, degreaser and scrub what I can get to. Then I want to pressure wash it out. But I am not sure the pressure washing is a good idea. Don't want leaks inside. Anyone have a good procedure for cleaning out the cowl?
Big Chip
Michigan
Kevin
C35
I’d have burned that thing to the ground if I found all that in the cowl but maybe try bleach in a spray bottle and a rag or sponge on it.
SubDominant
California
Keith
V1500
5.7L
Oy! I just sat there a stared at it. Then sang "It's too late to turn back nooooow!!"
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
How did all those wrappers get in there? You park this thing in the landfill?
SubDominant
California
Keith
V1500
5.7L
This thing hadn't been registered since 2012. Passed hands and was used as trail rig. Not taken care of at all. Last owner planned to make a KOH truck out of it and then changed his mind. I never saw what was in the cowl until I got it home and really began looking it over.
Rodents had a field day!
SubDominant
California
Keith
V1500
5.7L
Alternating courses of Simple green, scrubbing, 10 to 1 bleach solution soak (7 - 10 minutes) rinse lather and repeat and now its a bit cleaner:
MisterB
Northwest
AJ
GMC K2500 4X4
Looks much better, but while you've got it all apart and cleaned, I'd redo your seals. I see a crack all along it, and you could have a leak
Sent from my SM-N975U1 using Tapatalk
SubDominant
California
Keith
V1500
5.7L
Definitely will have to get back in there and take care of that.
350 w/203
You might want to pull the blower motor and check for junk/trash inside there.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
This is something I still need to do. I want to pull it and put a newer model in anyway. There was a thread on here at one point talking about putting a GMT800 (I think?) blower motor in. One from the 90s. Apparently it makes for a nice upgrade and increases airflow.
350 w/203
I've heard that too but cannot confirm it and have long forgotten where that thread is.
2manysquares2care
