Mike Harrington
- Apr 27, 2020
- Briggs,Texas
- Mike
- K3500
Howdy, new guy here and I need a little help. I've got a 1989 K3500 with a 454 and manual 4 speed Muncie tranny. The original engine spun a main bearing so I went a bought another big block engine they was used. The guy said it was a 454 and I pulled it out of an 1994 Chevy K2500. I don't think the engine is the original so I looked up the block number and this is where it got interesting....the numbers are 12561359 only that block number doesn't exist in any Chevy database I've looked up. There is a 12561357, and a 12561358 but none with a 59. And it's a very clear casting so it can't be mistaken for an 8. Can anyone give me any info on this engine and what it is? I think it's a mark VI block because the 6 bolt timing chain cover that is aluminum but its also got provisions for a mechanical fuel pump and I thought that none of the Mark VI blocks had that except for one certain casting number. And the casting numbers on the heads are 12562932 which when you look up it says they went to a Mark V crate engine. Any input or info greatly appreciated
