Need H6 AC compressor brackets for 454
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
It's been 4-5 years since I installed the pump, but in the last picture, I had to transfer that rusty looking nut from my old pump to this new one. I think the other had some type of stud on it. When I had the original A/C brackets on (below) it the pump would not have gone on had I not swap it out.
Squarebody1985
Right on ....... Thank you once again!!!!! I would give anything to find a unmolested engine compartment truck like yours, you have a awesome piece man
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Thanks for the compliment. I’m lucky the truck was parked for 10-11 years before I bought it. It also helped that at the time all those photos were taken I was living in California and had to smog it every 2 years. Everything on there was required to pass.
1tonguy
Minnesota
Howard
apache
I think I have the brackets for the longer ac compressor on 78 big block, but my problem is figuring out where they go.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
If you have the same brackets as mine in the above post, here's how the rest go.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
So, did I understand that that bracket set did work for the HR6 compressor?
@Squarebody1985
@Craig 85
The brackets I purchased are designed for a Sanden (508 in my case) compressor. Although the HR6 is similar in size I don’t think the it would work with my brackets.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Yes sir, I was hoping that the other poster would also respond. Seems he had an A6 and was replacing with HR6 like me.
keithself68
