Craig 85.......... Thanks for your response!!!!!! First I want to say that it is so good to see a unmolested engine compartment!!!!!! Now if you don't mind me asking for more info, do you by chance know the part # from vintage air? Are your hoses new in those pictures?....If so where did you get them? Thanks for your time, and help!!!!
At the time of the photo I lived in CA and had to have the truck smogged every 2 years. Luckily here in TN we have no smog test, but all I've done to date is remove the smog pump.
FYI there are 2 smog set ups for 1985 trucks. Pre 1/1/85 and post 1/1/85. My truck has a 11/84 build date and 1984 spec smog with the A6 compressor. Trucks built after 1/1/85 have dual smog pumps and the factory looking headers. Those have the smaller A/C pump.
The bracket I used is a Vintage Air VA151370BCA. I think it's made by Alan Grove. The Compressor is a Sanden SD5S14, Model #S6626. The hoses were custom made by the A/C shop. He was a Vintage Air dealer. Other than these items, the rest of the system is factory GM. I did have to change the belt sizes and order on the crank pulley.
