MtBraun
- Sep 27, 2017
- South Dakota
- Matt
- K10
Setting up my first diff, front D44 on this build. First pattern, (not pictured) showed contact angled across the root and coast side was centered. I removed pinion depth shims because that pattern suggested pinion was too deep. Now I am having a really hard time making a drive side pattern. It is very faint despite putting all the resistance I can with one hand while turning with the other. You can see in the pic how the marking compound is “peeling” towards the valley in the drive side gear. The last tooth though appears to be high, which suggests I may need to add pinion depth shim.
Backlash is a little high at .009 but within spec.
I am reusing gears and am confident it wasn’t set up correctly to begin with, so is it possible incorrect gear wear is affecting the pattern? I would appreciate the experienced and critical eye. Thanks.
