need engine help
87ChevyR10
Kansas
NA
NA
NA
So what all goes into pulling off the valve cover also all other cylinders tessted above 150 psi some at 170
Simply remove the bolts holding down the valve cover. No need to drain the oil. Heck, you can run the engine with them off.
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
Cool so extra questions I put in a radio now my dash lights and running lights don't work what did I do?
gpmorgan
Tupelo Ms.
greg
Make sure the fuses are good.
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
I did that however I discovered it's blowing the big 30 ampers lol
If it is blowing them that is most likely a short causing that.
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
Any common shorts I matched up wiring diagrams so I shouldn't have a shorto
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Could be a short to ground instead of a connection issue, like a wire that got pinched when you were pushing stuff back in the dash. Look for that too. Also double check your constand 12v source if there wasn't one there from the factory.
sam s
