Need an EFI recommendation
1low4x4
Nick
Here’s a thread to my build
Truck is a 350/4l60e. Dad took a GM efi system out of a Chevy van and installed it on the truck so it already has electric fuel pump. It has never run quite right because of the cam size and the fact that it never had a computer or chip tune. We are not interested in getting it tuned, I looked into that on the gearhead forum a decade ago, and they said that with the computer we had, the truck shouldn’t even be running.
My brother wants to go ahead and put a standalone EFI unit on it. Recommendations for under $1000?
Doppleganger
OH-MI: Just like it sounds
Under $1000? I paid $1400 for mine 4 yrs ago and they are now double that.
Might have to look for a used one.
You probably have too much cam,only reason I can think of someone saying TBI won't work.TBI is manifold pressure controlled big cams don't play well. With it. If you want to do some swapping around Vortec injection,TPI injection,or LTI injection might be a good swap. They are mass air flow controlled. Also Holley 2d injection,still TBI but don't think it used a map sensor. All this is from memory so do a little research or wait for others to chip in. Big Cam with TPIvwill need a bigger throttle body lower manifold and runners.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
I see them with regularity on marketplace, Craigslist and such at that price range out on the left coast but almost always taken off something for any number of reasons.
1low4x4
Nick
Why would they have gotten more expensive overtime? That’s not how technology works. FI tech had them for well Under $1000 a decade ago seems like.
Edit: unless Biden Harris
1low4x4
Nick
I don’t know much about these older systems, and since they are so old, I really don’t care to learn or play with other options. It’s pretty much either a standalone EFI or LS swap it. Unfortunately, this is a Frankentruck, with parts having being robbed off of like two other vehicles and put on this one. The truck runs pretty much normal and drives, but you can’t put the knock sensor in the block. You have to plug it into the harness and tie wrap it to something in the engine bay so the truck will operate. this truck down the road with plenty of power, but as you can probably determine, the computer isn’t getting that reading so it’s running off. I don’t think the cam is too big. I’ll have to find the numbers.
titos79
