Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
I need a lamp for my new gear indicator. But I only have the big lamp holders that came in my metal housed Autometer gauges. They are to big. It dawned on me last night that I still had all the lamp sockets that went to my original printed circuit. I looked to see if maybe I could make one out of one of them. Sure enough, with the brass tabs on the sides that are what clips into the printed circuit, I just might be able to solder two wires to the tabs.
Now that the iron is good and hot, prepare your wires by stripping off a small piece of insulation, the size will be determined by how good you are at soldering a tiny piece of wire without melting the wires insulating cover. Now what you need to do is "tin" the tab ends. Place the tip of the iron onto the tab for a couple of seconds. Brass is a good conductor of heat so just a few seconds will be plenty of heat on it. Now, feed a tiny bit of solder onto the tip near the tab so that a little drop flows onto the tab. Once you see that it's sticking and a tiny drop forms, get off of it!, and blow on the plastic socket to cool it down. Look at the little drop to make sure it's uniform and just covers the end of the tab as *seen above*.
Next, "tin" the ends of the wires with just enough to fill the wire up, no drop handing off the wire, a big glob of solder on it, none of that, just fill the wire then stop. The reason being is, you are not going to add any solder to this connection! The little amount on the tab and whatever you put on the wires will be more than enough *see above*. Now get the iron in one hand and the wire in the other and get the hand with the wire in a steady position. You cannot be waving the wire around while you're trying to get it soldered just on the tab's drop of solder. Now place the wire onto the tab, and here's where the "steady" part comes in.
Place the tip of the iron onto the wire and watch the drop of solder on the tab, and the solder on the wire. You'll see it turn liquid at about the same time, and if you have the wire placed down on the tab well enough as soon as you see it turn to liquid, get off of it, and blow on the connection until you think it's cooled down. Again, the least time on the solder the better, that's just that mush less heat on the plastic.
Now do the other wire in the same manner making sure you got the wire hand steady, apply just enough heat to turn the solder to liquid and get off. Now you're done, *see above*.
To start make sure the tip on the soldering iron is clean, clean, and properly "tinned". To begin with put the socket in an appropriate holder of some sort. Okay, then plug your iron in and go do something else. The reason being the hotter the iron is the faster the solder will flow, and that's what you want, because the least time spent on the thin little brass tab the better. You certainly don't want to get the tab so hot that it melts the plastic of the socket, it could mess up down in the bottom where the bulb goes.Now that the iron is good and hot, prepare your wires by stripping off a small piece of insulation, the size will be determined by how good you are at soldering a tiny piece of wire without melting the wires insulating cover. Now what you need to do is "tin" the tab ends. Place the tip of the iron onto the tab for a couple of seconds. Brass is a good conductor of heat so just a few seconds will be plenty of heat on it. Now, feed a tiny bit of solder onto the tip near the tab so that a little drop flows onto the tab. Once you see that it's sticking and a tiny drop forms, get off of it!, and blow on the plastic socket to cool it down. Look at the little drop to make sure it's uniform and just covers the end of the tab as *seen above*.
You can see here the amount of solder it takes to do this little fix, not much. It would have been better had I thought ahead and put a little bend in the wire so the wires would be hooked around back of the socket, but no matter, there's no telling how it'll be put in wherever it needs to go. If I have to bend the wires, I'll have to be very careful not to damage the tabs. Insert the bulb and it's ready to go in to light up the gear indicator.
