nee in wi
454play
Wisconsin
Don
This is my second square my first was a clapped out 85 3/4 ton beater. Now I have what started as a 78 half ton i got it with a hot 454 and a 700r4 which in short order chewed up that half ton rear. So I'm in process of 14 bolt ff and a little more lift going from 33 to 35 new diffs have 4.10 the half tons were 4.56 so I'm loosing a little gear but I can always fix that later. Ill try to get some pics up soon I'm just soaking up info for now I'm pretty mechanical but I'm learning what all can swap to where easily. On that note how hard is a 205 to put in place of my 203?
davbell22602
Bunker Hill, WV
I Dont
Have
One
Welcome. Got any pics of the squares?
Howdy!
So you have a 203 behind a 700R4? That's an odd combo. If you do in fact have a 203 in there already, a 205 will swap right in, using the spacer you already have in there, and a th350-np205 adapter. Of course you will also need an np205 from behind a th350.
454play
Wisconsin
Don
I'm finding lots of little odd things on this truck but that is great news thanks a bunch
Milkshake
