Mystery Plug
84 Silverado
Dallas
Tod
Silverado 1500
Good Sunday Evenin' Gents.
I was digging around behind the distribtuior on my 1984 350 Silverado and found this plug just chillin out, not pulgged into anything. Does anyone know what this thing is?
Turbo4whl
Downingtown, PA
Wayne
You are hiding the colors of the wires. If they are both blue, then it is the plug for the electric choke pressure switch.
84 Silverado
Dallas
Tod
Silverado 1500
All wires are now shown.
Turbo4whl
Downingtown, PA
Wayne
Yes, that is it. Test, turn the key on, no choke light on the dash. Unplug the jumper wire. If the blue wire at the carb is plugged on the electric choke the way it is supposed to be, the choke light now will be on.
Wallace6
Wyoming
Ray
Suburban
Where is the choke light at?
Wallace6
Wyoming
Ray
Suburban
I will definitely have to look but I think mine says something along the lines of fasten belts.i will check in the morning,thanks
Finkaire
Finkaire
California
Loren
Silverado c10
Pressure switch right above the oil filter three wire plug connected to a 2 prong switch. Mine leaks, in the process of replacing
dannyphx
