- Apr 11, 2017
- kansas
- Rick
- c20
VW bugs. Gas tank,covered by the hood and vehicle belly pan below it. They rust out commonly.They rust from water in the tank. They also do not have a sealed fuel tank assembly as in basically the same as a vented gas tank.Condensation from the non sealed system contributes to the moisture problem.Gas evaporates , expands, vents and moisture and humidity from the atmosphere replaces the evaporated and burned fuel.Fix your evap. Systems people. And run a can of heet or alcohol blended fuel occasionally.
