My ignition timing is going crazy
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
So I've been fighting a power loss for the past few days and I noticed it was beginning to run like pure dog ****.
I had replaced the advance weights/springs as I thought maybe that would help.
But the engine started to run like poop in the 3k+ range
So, I changed my advance springs to a less tension one and that moved the poop range down to 2k lol. :roflmao:
Checked the timing and my base timing was at 46° :whoa: :insane:
:yucky:
I had it set at 21°.
SO, I reset the timing and it was running great.
Backed it out of the garage to take it for a test drive and it started running like **** again like the distributor is just advancing itself.
Didn't check it, because at this point I was getting to pissed at it. So its just parked now.
Is my distributor shot?
Thing is tightened down pretty good.
This is driving me crazy lol
animal
Lee
c10 silverado
350ish
I had the same problem with mine at 1 time. I finally had to get a different hold down for the distributer. Even though the hold down was tight the dist. was moving as I was driving.
Just a thought.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Also consider the distributor gear, camshaft where the distributor gear meets, or the timing chain.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Just a thought.
The hold down holds it pretty good
I cant move move it around
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Lol timing chain was replaced almost a year ago
Snapped my crank sprocket in half so I went ahead and replaced both gears and the chain :crazy:
crazy4offroad
Curt
K-10
350/SM465/NP205
Sounds like it's time to pull the distributor and check the gear, maybe the roll pin sheared.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Yeah looks like I'll be doing that tomorrow
82chevy350
Van Buren, AR
Joey
C10, K10, K5
yup sounds like the gear on the dizzy shaft
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Well I got bored so I went and pulled it out
Gear looks fine. Doesn't seem to be any play
Does look like it might either be a combo of the center weight being upside down and maybe it being on the wrong vacuum port on my carb.
I'll have to look into more later
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Looks like my advance weights were sticking lol
Still don't see how it was at 46 lol
Total should be about 31-33°
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
are you still running the stock Hei distributor or did you switch to a aftermarket unit?
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Its a Delco refurbished one
85k10383
Glengary, WV
Ross
K10 Scottsdale
Notice, he did not say Delco "well" refurbished LOL 46degrees of advance, Wowsers!
I had the same problem with my Mallory, it was to much weight for the cam.
jlyon1006
