My first complete SBC 350 build
Oaasport
Justin
Suburban V10
Hey Everybody! I wanted to share a mild engine build I am doing. I scored a never-bored 350 4 bolt main from my machinist. Since I wont be driving the truck much, I decided I was going to build it to run on premium. Right now the block is being bored .040 over with flat tops. I got Vortec 175cc/64CC heads from Summit Racing. A Comp Cams CL12-239-3 4x4 cam and lifter kit. Summit Dual Plane Intake Manifold, 1.5 self aligning rocker arms, Edelbrock 1406 (maybe too small, its reuse carb lol) Heddman 1 5/8 headers, and a Summit High Volume water pump. I am hoping to see 400ftlb out of it. Thanks for all the projects posted to help keep me going!
Joshua Keith
Memphis
Joshua
How’d this engine turn out for you?
cstew47
colombia
craig
Sounds like your CR will wind up around 11:1. Definitely will need 91-93 gas. I don't see any reason that you would need a bigger carb. It would probably be a detriment.
Raider L
Shreveport, LA
William
@Oaasport,
Just trying to get a better idea of what you're doing and what you're working with.
You say a never bored 350 and you decided to bore it .040", how many miles did this motor have on it when you got it? And it was out of a what? What did the cylinders mic at before you bored it? What kind of pistons are you putting into it? Pop ups? And your id says you have a '87 V10, is that what it's going into?
JoeyPepperoni
