My first build, I turned this into that
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
and ultimately into this
04 1500 4x4 SLT 4.7 re-worked heads HO cams Melling rockers, lifters, valves, springs oil pump, Cloyes timing set, FEL PRO gasket set, HO intake, Spectra Cold Air intake, Gibson headers, Magna Flow cats, Flow Master old school 40 with twin turn downs, NGK coils, new design injectors, Flex-a-Lite 183 e-fan 3 inch Performance Accessories Body lift, 5 inch Rough Country Lift, 5 inch Sky Jacker Soft ride rear springs , 2.5 RAMM CAMM torsion keys, Cooper SST 38x13.50's on Weld Off Road Sling Blades20x12 Neg44. 4.56's front and rear. Spyder projection headlights with led/halos. Smoked led third brake light with smoked led taillight assemblies. AMP Research powered running boards. Truck painted in GM white Raptor Liner
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
the lift came with a replacement truss, and this particular lift drops the front diff down via brackets,, no cutting or welding.
MarineOne
Western New York
not the mount bracket. The half ton front different are glass and are known to Crack housing in half
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
OHHH I got ya. Na so far so good. I do not thrash it much. But I have seen the pics of where they do crack, and I do keep an eye on it. This is just a fun wheel around town truck for me and my wife and grandchild to enjoy.
Doug Hampton
