geolee
- Mar 5, 2018
- jacksonville, illinois
- george
- c10
Just got a 94 short bed standard cab Chevy after I got done with the 84 c10. I did a little preventative maintenance and ended up getting bad parts from oriellys. Spent over a week trying to figure it out. After I got it driving home the check engine light came on so next day I hooked it up to a scanner at work and it said egr problems so I got a new egr then did plugs wires, ignition module, idle air control valve, coil, throttle position sensor and after that it would turn over and not start. Figured maybe got a bad ignition module so I got a new distributor and still same thing. So then after double checking everything I put the old throttle position sensor and idle air control valve back on and fired right up. Just thought I would pass the info on maybe to help someone out later. Today I got a new iac and tps from Chevy and it runs perfect. Lots of brand new junk parts out there these days
