My-6 new process 3-speed overdrive
malibuman402
nc
Larry
C10 Silverado
BB 402+.060 = 413.8CI
I have a np833 in my 84 c10 behind a 427 big block. i love the trans. i have 373 geared rear end and the truck runs great. you can get rebuild kits from BREWERS, a web site dedicated to mopars. but they have the rebuild kits for the MM7/MY6 gm transmissions. I think the only part that's exclusive to GM is the input shaft. there is another web site called passon performance out of PA that sells parts for the NP883. hope this helps.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Good info and awesome truck! My 833 is a MM7 steel body with the flat Hurst shifter in my 85 K10. Midwest Transmissions rebuilt mine and I just recently got a shifter from Shifter Doc.com. I plan to rebuild my wore out shifter and save it or sell it.
malibuman402
nc
Larry
C10 Silverado
my MM7 has an aluminum body and weighs about 125 lb's. you can get parts for your shifter on the hurst web site.
The aluminum case 883s wear out the case where the countershaft rides,like the Muncie m22s,they can be bushed.The cast iron cases don't. Just FYI for people looking for these gear boxes.
Keith Seymore
Motor City
Keith Seymore
4.3L
That sounds a bit heavy.
I was able to lift it out and back in without assistance (not like a TH400, for example, where I use the floor jack).
K
