My-6 new process 3-speed overdrive
siataspring850
delaware
mike
c/10 step side
I have a 1987 step side 4.3 with the new process 3-spd o.d. I read on this site that in 1987 Hurst sold to Mr Gasket so only 300 trucks were sold with this set up. I am pulling the tranny soon and swapping it out with a Saginaw 3 spd. The MY-6 sounds like it has the input.. bearing going bad
My question is since only 300 were made and 87 being the last year should I rebuild the old tranny and keep it stock? Also does anyone know if the drive shaft will match up? I cant get under the truck until next week and if I need to change on the drive shaft I'll have to get one before I do thew swap
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Wouldn't be a bad idea to rebuild. You definitely have a Gem. If anything keep the original around
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Not quite what I said;
I said that 100 were built under the Temporary Deviation (one of which happened to be mine).
I don't know if they went back and opened up the production volume if/when the supplier issue was resolved.
K
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Not sure about this, either.
Since the MY6 trans was also available in the full size Blazer it conceivably could have been had in the '88 and '89 V Blazer models.
Unfortunately those generic info packets are not in the GM Heritage Center archive so I can't verify.
I can say the '90 and '91 V Blazer info packets are in the archive and the MY6 trans is not specifically shown as available.
K
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Yes - I would keep the MY6.
It's a cool little trans, plus you get the bragging rights of having a MOPAR trans (and the cool Hurst shifter) in your truck from the factory.
And - it is admittedly rare-ish across all the model years, regardless of if the number is 100 or 300 or 10,000.
Did I read somewhere you have a 3.08 rear axle? That's probably what is killing your off the line performance/launchability.
I would recommend a 3.73 rear axle ratio, which will really help off the line and with the overdrive it brings you back to (an effective) 3.42 ratio going down the road.
K
siataspring850
delaware
mike
c/10 step side
Thank you for all of your replies. I think it is a great truck. I am going to pull the tranny and see what is up with it. If it is a throw out bearing I'll be lucky. Normally I could feel the throw out bearing through the clutch peddle. But I might have lost that skill set. They shouldn't be hard to rebuild I've rebuilt top loaders many many years ago.
Some times I just have to reach out and get a feel for what others think and know. I am going to pull the tranny and see what is up with it. I will let you know how it turns out
The value of the truck is I like
Thank you all again
Drive shaft will work,bellhousing probably will not. Make sure your bellhousing has a bolt pattern for your new transmission.
CudamanSquareBod
