- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
It sounds almost like your choke pull-off isn't working. Did you go through and check and set all of the measurements properly based on the setting provided in the booklet that came with your rebuild kit? I'm a little concerned that when asked about an exploded diagram, you said it was a link to a youtube video, as that was not at all what I got from them with my rebuild kit. You Should have gotten a folded up bunch of papers that had an exploded view of your carb with part numbers and also a numbered list of illustrations for checks and settings that are applicable to your carb. There should also have been a page with a list of settings for specific applications. The idea that you just eyeballed your float level makes me think you didn't do this.
