May be beating a dead horse here, but any source for clutch rod inner/outer floor boots?
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
After an hour of fruitless searching, I finally decided to ask all you experts if anyone has found the inner and outer clutch linkage boot seals where the rod goes though the floor?? I saw that someone located a similar boot on McMaster Carr, but everywhere else seems to be a dead end over ten years old.
Seems like a fairly common, and always need part for a large number of trucks. Of course, mine is busted into 3 pieces and the air gets in.
SS1019
St. Helens, OR
Steve
C10 SWB
Looks like Classic Industries has some. Maybe a bit of a universal and seems a bit spendy but it would plug the hole!
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
Yes, $40 is too much for me. I will be trying this one:
Hopefully it does the job, it certainly looks pretty close to the original.
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
The above rubber boot arrived today, it looks nice and will probably work.
It looks to be almost identical to the original:
It does have the metal base ring molded in. Not sure if I can work on this project before the beast goes into hibernation for the winter. I am still waiting on a new radiator to arrive so I can drive it again before the snow.......
BrianBaca
