Manual transmission swap
pmehringer001
Indiana
Paxton
V20
I have a 1986 D30 with 6.2-th400-np208. I have an 80’s sm465-np208, and a 70’s sm465-np205. I plan to use the 205 t-case. But is there any differences between the transmissions being 70’s vs 80’s? Is one better/stronger than the other? Slightly different gear ratios? I had already bought a rebuild kit for the 80’s trans but would it work for the 70’s trans if I decide to use that one?
SquareRoot
Hi. There might be minor differences in the transmission years, I don't know but someone will. I know about 205 t-cases and NV4500's and auto to manual conversions. Do you plan on a mechanical or hydraulic linkage? 85-87 came OEM with hydraulic you know. Do you have the pedal assembly yet? Vacuum or hydraboost? Not trying to be nosey but I can help you out with info and parts if need be.
nvrenuf
Mobile, Al.
'84 and older 465/205: the 465 has a male 10 spline tailshaft, the 205 has a male 10 spline input shaft and they are joined but a coupler sleeve. These will have a tall figure 8 bolt pattern adapter.
'85+ 465/205 and all 465/208: the 465 will have a long male 32 spline tailshaft, the tcase will have a female 32 spline input shaft. The 465/205 will use a short round bolt pattern adapter. Iirc, the '84 and older 465/208 will have a tall adapter where the '85 will be the short style.
Gear ratios in the early and late 465's are the same. Aside from the tailshaft, I believe all of the parts in the rebuild kit will interchange.
pmehringer001
Indiana
Paxton
V20
I plan on using hydraulic clutch. I don’t have any of the pedal or pedal related parts yet. It is hydro boost brake system.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The pedal and bellhousing/related parts are hard to find and expensive.
pmehringer001
Indiana
Paxton
V20
Yeah thats what I’m coming to find out . I have a hydraulic throw out bearing thats supposed to take place of the manual one with the same bell housing. Pretty much all I need now is the pedal assembly, slave cylinder, and hydraulic line/resevior.
SquareRoot
I know someone who has those hard to find parts ;)
Zelph
Nevada
Fat 454
Australia
C20 Suburban
Novak transmissions sell ( or used to ) a hydraulic conversion kit for a chevy bellhousing. Good source of transmission swap info as well.
I believe they still do.
alcompton1986
