Making my 1990 Suburban bullet proof. What do I need to do?
Giant Rock
Joshua Tree, CA
Cole
Suburban v1500
5.7 V8
So I bought my Suburban about 4 months ago and I absolutely LOVE it. I'm gonna keep this thing forever. It has 206k miles on it but seems to run great. I've already done quite a bit of deep desert exploring in it, using 4x4 often, but plan on doing even more in the future. This last weekend my wife and I were absolutely in the middle on nowhere, running some mild, rocky jeep trails. The thought occurred that if the Burb broke down or stopped running we would really be screwed. Obviously, you're much better off exploring with a partner and second vehicle but that is not always possible.
I'm planning on upgrading the suspension with custom Offroad Designs recommended parts (found them thanks to this forum) but I was wondering what else you guys would recommend in order to make the truck, engine and everything included, as bulletproof as possible? Also wondering what you would say is the most typical way it could break down and what I could do about it in the field or how to prepare for that?
I'm a total noob so any advice, regardless how basic, would be greatly appreciated.
View media item 9354
AKguy
Alaska
Randy
K30 Crew Cab Silverado
I’ll start with making sure you have good load range E tires, two spares, air pump and a plug kit. After I created an access panel in the floor of my Tahoe I carried a spare fuel pump, too. Don’t know if your model has the in-tank pump.
I’ll just say if you are regularly in a place with no cell reception, miles from the nearest person, you should get a satcom that uses the iridium network. I personally use an inreach mini, but that’s mostly because I work for the Garmin Aviation group and get an employee discount. It’s one of the go-to items for trail runners, hikers, and pilots that have a chance of ending up in an emergency outside of cell range. There was a guy a few years ago out here in Eastern Oregon that was wheeling in his jeep with just him and his two dogs and got it stuck waaaaayyy off trail. A guy on a cross-country mountain biking trip found him passed out in the middle of the road and hit his SOS button on his inreach. About 45 minutes later an ambulance rolled on down the dirt road and loaded the guy up and hauled him off. The guy in the mountain bike kept going to finish his bike ride and ended up finding the guys jeep tracks headed off into the desert like 15 miles down the road. He called the sheriff to let him know and they found the guys jeep a few miles off the road with one of his dogs still hanging out around it.
Blackbeard44
Washington State
andy
6.0 LS
make sure proper maintence is done with high quality parts, no cheap belts,hoses and tires, making something bullet proof is a never ending chase.
if your just poking around driving slowly these rigs are pretty darn stout to begin with, but if your are mad max everywhere and trying to catch air than alot of work is needed.
spare ignition module or 2 is always a good iea as well as 2 spare tires.
I would focus on just making sure everything is up to date maintence wise and have spare parts and tools on hand
One of the guys I used to work with use to say,we can make them bulletproof we can't make them idiot proof.
Curt
Loco Hills
Curt
K-30
I dig it.Into the same type of wheeling myself.First I would focus on your survival,not unless you want someone else’s driving your ride.
Water,throw in some protein bars,life straw,warm clothes and a way to start a fire.First aid kit.
Everyone has mentioned most of the parts to carry.Good set of tools,variety.You can do most front engine work with a 1/2,9/16,and 5/8” wrench.
I carry extra belts,hose clamps,long spark plug wire,A shovel and a high lift Jack is good.Winch is a great advantage.
Most importantly,common sense.If you do extreme things,expect extreme results.
Maintenance is so important.Address known issues or suspected issues before going out.
I got started by reading a book about Chevy trucks by Jim Allen.
Curt
Loco Hills
Curt
K-30
I looked at your post again.To answer the 2nd part....there’s not much there to make bullet proof on your engine.Making sure your wiring is nice and tight,not exposed,in good shape.Adding a 2nd battery for more reserve is easy.As Blackbeard said,use quantity parts.I know it’s cold now,but since you have desert I would guess it gets hotter than hell.Make sure you cooling system is tip top.
Gm made some really heavy duty drivetrain parts.What you have now will survive depending on what you’re doing.Just riding around,exploring with 4 wheel drive is what the truck was made for.Wheel it,see what happens,upgrade as needed.I’d look at driveshafts,ujoints.Especially the front CV joint.Make sure you grease it.You’ll need a needle attachment for grease gun.Factory front locking hubs are weak.
Might as well start a maintenance schedule or follow manufacture’s schedule.Your blessed to have internet on all kinds of info.
Frame failure is common around the steering box.You mentioned offroad design,I would get the steering box brace for your truck rather quickly.Until then,take one bolt out at a time,apply blue thread locker and tq to 85 lbs.Check periodically for proper torque.Don’t bang that transfer case on a rock,your day will turn to ****.
I forgot to mention earlier that a fire extinguisher is important.Watching your truck burn down,you may not recover....
gmbellew
Kansas city
glen
suburban 1500
keeping up on maintenance is key.
i keep all of this in my well maintained 90 burb at all times - owners manual in the glove box. extra fluids (tranny, oil, coolant, power steering, etc). basic tool set. a spare ICM. spare headlight (1 high and 1 low). spare fuses. spare random bulbs for other lights. jumper cables. tie downs and ratchets. traction boards. tire patch kit. zip ties. army shovel. that is all just for road trips and the bouncing around the farm driving.
if i were having remote adventures, i would add: spare hoses and a belt. a way to air up tires (onboard air or a small tank). spare fuel. potentially add a front locker or posi. battery jump pack for emergency starts of a dead battery. i already run a spare battery for double cranking amps and extra capacity. but if not, you may consider it.
and the aforementioned emergency kit and supplies for you.
Auburn, Washington
Cost is relative. And this thread isn’t about what repair or survival gear your bring with you. Different topic.
How much do you want to spend and how old are all the components? Make a list.
Major components rarely fail suddenly. Engine internals, trans, case, axles if they’re in good order and well maintained that’s about all you can do save for major rebuilds to make them new again.
All other ancillary components are up to 30 years old depending on when if they’ve been replaced.
The bulletproof answer is replace all hoses, tune up components, engine accessories/pumps, u joints, brake components.
But you can pare that back to what’s verified newer or in good condition and also what will leave you stranded vs what you can limp home with.
I was a recovery operator and mechanic in the army and the general method for recovery or battle damage repair in out of the way areas or under fire was to have a lot of generic repair materials. Things like quick cure J-Weld, clamps, a knife and/or leather man, crescent wrench, BFH, hoses of various sizes, all the fluids of various types, 5 gallon jug of water(for drinking or emergency radiator fill).
The reality is if you do proper maintenance and inspection on your vehicle it is already pretty bulletproof. You can only plan to be able to handle any random emergency and do the best repair possible to get you out to somewhere that you can do more permanent repair. As a kid my family tooled all over the southwestern US in a 1973 Ford F-150, 2wd. To include many trips up and through the back country around Death Valley and up into the eastern side of the Sierra Nevada’s. Just don’t do stupid dukes of hazard stuff and plan to be able to handle emergencies and you should be fine.
rt66paul
California
paul
1991 suburban
I am installing an inverter in my 91. I had one that I just clipped to the battery, but someone stole it when they broke in. New cars come with these, you have a couple of cigarette lighter connections, some usb ports and 110v ac plugin(s). If you have a second battery, you don't even have to leave the engine running while you are using power tools or some extra lighting while parked.
Salty Crusty
Gary
c1500
^ sounds like a great idea.
I'm equipping mine with Milwaukee impact, ratchet, HackZall and Chainsaw, all Fuel. I have an extra charger I'll wire in, double batteries seem almost like a "must do".
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Won tons and a SOLID cooling system. :)
2manysquares2care
