M1009 Engine Swap ID
jmill17
Nebraska
Jason
Recently picked up an 86 M1009 blazer that has a small block in it. What engine is in this thing? Attached are pictures of the numbers on the front pad and behind the drivers side head. Front pad is VM2328O0 and rear is 14016379
1x1_Speed_Craig
Chuckey, TN
1986 M1008, 1985 M1028/C10 mutt
6.2L diesel
You'll want to sign up on SteelSoldiers.com, if you're not already. There are a lot of CUCV owners there (myself included). If it's a stock engine, it will be the 6.2L diesel.
CheemsK1500
K1500
If thats the original engine in that truck, its a 6.2 Detroit diesel (Not to be confused with the 5.7 Oldsmobile diesel). If its has been swapped with a gas engine or a different diesel, someone here can probably tell you what it is, if we get a picture of the whole engine bay.
Dmack
Central OR
Dave
Quick interweb search indicates 77-79 350sb.
Rickf
Grafton NH
1974, 1954 & a 1937
Most likely a 5.7L (350) gas.
2manysquares2care
