M1008 1985 Michigan
IHC656
Michigan
Tony
1985 5/4 ton Chevrolet Ex-Military truck. 79K miles $7500
GM (Detroit Diesel) 379 cu in. (6.2L) J-series non-emissions diesel V-8 engine
GM TH400 (Turbo Hydramatic 400) automatic transmission with 3 forward and 1 reverse speeds
Manual NP208 2 speed transfer case
Hydraulically activated, power-assisted front disc and rear drum service brakes
NATO slave cable receptacle
Lockout hubs on Dana 60 10-bolt front axle.
Detroit No-Spin diff lock in GM 14-bolt rear axle
Reese hitch
Brush guard on the front bumper
Pintle hook mounted on rear step bumper
Towing shackles mounted front and rear
marks86
Latham, NY
Mark
12v Cummins
Lockout hubs on Dana 60 10-bolt front axle. (Spicer limited slip Trac-lok diff)
Reese hitch
If it has a trac lok then its a m1028 does it have helper springs?
IHC656
Michigan
Tony
This is my father truck. Which is a M1008.
I was going off my truck which is a M1028 with a M1008 cab.
I corrected the add. Thanks.
He has new carpet in the cab, added chrome drip guards above the doors and has a 12 volt trailer outlet with a reese hitch.
marks86
Latham, NY
Mark
12v Cummins
no problem, very nice CUCV ones in this kind of shape are getting harder and harder to find GLWS
IHC656
Michigan
Tony
Bump
yeti_87
