LS swap parts list
Deek50
California
Derrick
thought this parts list might help any one looking to do an LS swap. Here is the parts list i have so far for my 1975 K20 LS swap not sure if I am going to use the cam listed or not but it is a good place holder.
LS Swap Flat bed
PartPart NumberVendorPricePurchased
GM 6.0 L 2003LQ4Pick and pull 50% off day$ 207.00X
Fuel tank 20 Gal. X2Spectra GM1CAmazon$ 221.50X
Sending unit driver sideSpectra FG05Mauto zone
Sending unit passanger sideSpectra FG05Nauto zone
12"clutch kitDuralast Clutch NU1909auto zone$ 266.45X
In Tank Fuel Pump X2Areomotive 11569(340 Series)Amazon$ 265.30X
Bell Housing BoltsICT BilletAmazon
Master Adapter SetICT BilletAmazon$ 57.48X
Fuel fittings
ECU flashHP tunersHP tuners$ 100.00
flywheel for use with SM465Sachs NFW1050Rockauto$ 116.30X
Flywheel boltsITC BilletAmazon
Pilot BearingGM CT1082Amazon
Pressure plate boltsARP 1342201Amazon$ 57.09X
Brake Booster Vacuum Hose ConnectorGM12559760Amazon$ 9.50X
CamshaftSloppy Mechanice "best cam"Sloppy Mechanics$ 265.00X
Valve SpringsPAC-1218Glenns auto preformance$ 149.99X
Fuel tank paint blackLocal painterBrad park(Devilry Customs)$ 160.00X
Clutch Master CylenderWilwood 260-15098Amazon$ 65.06X
Hydraulic throwout bearingRAM 78125SummitX
clutch Hydraulic hosesAllstar Performance ALL46304-42Summit$ 174.67X
Nylon Fuel line 3/8 25ftFLRN-625Zoro
Nylon Fuel line 5/16 25ftFLRN-525Zoro
3/8 fuel line clampsFLRC-2982Zoro
5/16 fuel line clampsFLRC-2980Zoro
Fuel line adapter 3/8 steel to 3/8 Nylon2 per bag)FLRL-075Zoro
Heat Shield sleeveFLRT-14005Zoro$ 112.34X
Total Cost$ 2,227.68
If you want a great cam with a decent budget, you can send the stock cam to Delta Camshaft in Tacoma, Wa and they will regrind it to whatever spec you want. They have been doing it forever. Just call them and tell them what you are doing and what you want out of it and they will recommend a grind and do it for you. My l29 roller cam was $140 shipped and I had it back in less than 2 weeks from when I mailed it out.
born2Run83
West Texas
Justin
GMC - C1500
5.3L LM7
This is a great budget build! I went through Texas Speed for my 224R Cam and valvetrain etc. Engine came from LKQ Online. How many miles does your LQ4 have on it? It’s interesting you did this spreadsheet. It’s literally almost identical to the one I made to keep track of parts needed/bought and prices and vendors lol
Deek50
California
Derrick
Parts List update
Cracksaft seal FrontGM29602RockautoX
Oil Pan GasketGM12612350RockautoX
Timing Cover GasketGM12633904RockautoX
Water Pump Gaskets X2GM251663RockautoX
Rear cover GasketGM12639249RockautoX
Oil Galley PlugGM12573460RockautoX
Exhaust Manifold gasketGM12617944RockautoX
3/8 Nylon to quick disconectFLRQ020RockautoX
5/16 Nylon to quick disconectFLRQ040RockautoX
Cranckshaft seal rearGM89060436Rockauto$ 180.28X
Not sure How Many miles on the LQ4, I will update when I check the ECM
Think I might try a summit truck cam. I do plan o putting a turbo on the motor it will receive an HX35 with a V-band Hot side from Turbo Labs of America.
Cooltx
