Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
I never heard back but i imagine at basically from that screen shotLet me see if I can’t get that info
29degrees is too much for 800rpm.
You'd maybe want that under some other certain conditions like if the motor was hesting up, or the intake temps were really cool, or perhaps it was in gear and it needed more spark advance to keep constant vacuum.
I think you said LM7 ? I dont remember.
Yea 30 is a bit much lower 20's at idle in park would be better. That might be part of your lean condition.
The map kPa i asked for... you ought to be seeing anywhere 40-55kpa with that cam at idle.
If you arent, youve got a vacuum leak, exhaust leak, too lean or too much spark advance, or perhaps not enough airflow .
I doubt not enough spark advance, as i said 29 is alot to me.
Manifold vacuum falls for all of the above regardless ^
