Lowering my 1982 C10
bnhall
Billy
Need some help, I have bought and installed DJM lower and upper control arms. I also have order the CPP big brake kit that converts from drum to disc brakes.
I didn't know is that the BBK came with a spindle with a 2" drop and no where in the discerption does it say that, but anyway, My question is can i use the 2" drop spindle with the Upper and Lower control arms from DJM?
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Good luck shouldn't clutter
To answer your question you should be able to without a problem.
To reply to @Iowan cuz it's why not?
74 Shortbed
Welcome to the site!
Just a note, if you have lowered control arms the spindles will add another 2" to whatever the control arms are..
bnhall
Billy
Thanks for getting back to me on this. I have been racking my brain on what I should do. I am wanting a 5" drop in the front and i have purchase a 6" flip kit for the rear.
Next question how big can i go on rims and tires and what kid of offset will i need? Would like to run 20" on the rear and !8" on the front
bnhall
Billy
the lowers are a 3" drop bucket, I'm keeping the stock spring will that work?
@J Knight would be a good dude to pull into this convo. :) maybe he'll respond soon
74 Shortbed
You will have a 3" drop with stock springs if you want more you can do a lowered spring, don't do a drop spindle or the control arm will be way to close to the ground, they are too low to begin with.
J Knight
Baytown TX
82 Chevy
350ci
From what I have read, a drop spindle with drop cotrol arms is a bad combination because of the spring pocket too close to the ground. You would be better off with drop spindles and drop springs imho.
If you have all ready installed the parts, let us know how they work together.
bnhall
Billy
I just finished taking everything apart. The bolt kit that come with the lower control arm is to big to fit in the shock and two the bolt won't thread into the nut that is welded on the control arm!! Going to send them back to Summit. Any suggestions on where to go from here? Keep the uppers from DJM and go stock lowers with a drop spring, or go all different uppers and lowers?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Keep the upper ca's, drop spindle, drop coil and oem lower control arm.
74 Shortbed
My donor is a perfect example, it has 3" lowered control arms and 2 1/2" spindles with stock springs, those spring pockets are way too close to the ground, that is dangerous IMO..
KrazyKustoms
