Lowering 1984 c10 rear by 2 inches
SquareBobby
Florida
Bobby
I recently purchased a 1984 Chevrolet Silverado. I need new tires and would like to go ahead and get new rims also. I want to level the truck and will need to drop the back 2" to accomplish this. What is my best option to make this happen? I don't want to cut the bed.
Is the suspension stock currently? If so, your 2 options are moving the leaf spring hangers or adding a 2" shackle at the back. The 2" shackle will require cutting the bed brace just above the shackle if your truck has the 52" springs.
WFO
Texas Panhandle
Big block coil springs up front will level it up pretty good.
1x1_Speed_Craig
Chuckey, TN
1986 M1008, 1985 M1028/C10 mutt
6.2L diesel
Ideally, a combination of new main eye hanger and longer shackle would be the best to retain the proper pinion angle (unless shims are added).
FireTruck1984
Michigan
1984 and 1984
Easy! I leveled my ‘84 C1500 using 2” drop spring shackles in the rear.
Can’t speak on the hangers cuz I’ve never used them but I’ve never had to adjust pinion angle using 2” shackles.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
We did like @FireTruck1984 did. 2” drop shackles from Summit Racing. About 30 minutes and done. Nice and level.
Randy and E
1x1_Speed_Craig
Chuckey, TN
6.2L diesel
Fair enough, but that's completely anecdotal, and doesn't mean that your pinion angle was correct/accurate after doing so. If you're only changing one end of the leaf spring, your pinion angle changes. Maybe 2" drop isn't enough to have any significant effect, although I suspect it may wear your U-joint a little faster. Keep in mind that to achieve 2" drop, those shackles will be 4" longer. That's significant IMHO.
I won't claim to be an expert, but spent 20 years in the Jeep world where suspension changes are more common than not.
This is a good general driveline article from Tom Woods:
Bennyt
Surprise
Ben
Question, trying not to derail too much and this is most likely not relevant with the OP's '84...
But can you use lowering shackles with a stepside? On a steel floor fleetside you have to trim the brace but I believe on stepsides the wood floor would interfere. I ask as I believe the cross brace is substantially shorter and the top of the shackle would be in the wood floor.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
On a stepside you will have to cut the brace. The shackle will end up very near the bottom of the wood but does not interfere at least with my installation.
GorillaHumper
