Looking to swap a 1979 Bonanza to an Automatic Overdrive
midgetorama
Montana
Casey
Bonanza
My dad has an ultra clean 1979 Bonanza. Now that he's retired he's driving it more and hates the 4.10 gears at highway speeds. I believe it has the NP203 in it since it's full time 4WD and it's paired to a TH400 and 350 ci.
Can anyone recommend the most straightforward swap to an OD trans? I'm not opposed to a new transfer case swap with lockout hubs.
Happy to provide more information on the pickup to help with recommendations. Thanks!
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. When I read the title I wanted to answer: Ask NickTransmission.... but I was too late :)
NickTransmissions
Las Vegas
Nick
Thank you. It appears a 700 can be mated to a 203, though not optimal. Is there a recommended transfer case for this swap also? Thanks again!
You're welcome...I'm not sure on the t-case as that would depend on whether you had a driver side or pass side drop for the front diff but a nicely built 700R4, assuming your engine won't be making more than about 500 HP and/or full race, will make for a great cruiser on the hwy while still giving you decent city mileage (i.e you wont give anything up vs a TH350 or TH400).
legopnuematic
Licensed Junk Dealer
MO
Spencer
If you go with a 700r4, an NP208 would probably be the easiest solution as they are rather plentiful and came behind 700r4s from the factory.
They are plenty strong.
If you do go to a part time case, don’t forget to get some manual locking hubs.
midgetorama
Montana
Casey
Bonanza
It's a passenger side differential and I doubt the pickup will ever have more than 400 hp even the motor is rebuilt or swapped. I guess the search begins for a 700 core and 208 transfer case.
Thanks again for the info!
turnleft2goright
