Looking at car lifts
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I would love to put a 2 post car lift on the side of the house. They have 9,000lb ones for about 2k or so. That would be ideal but, would have to ask the city because I'd hate to buy it and them come by and tell me to get rid of it.
Saw this one at HF for 1,800. It holds 6,000lbs and is movable. Heavy but you can move it.
https://www.harborfreight.com/6000-...-zk_Mb93BHKYUr056wTBK-BbqQ9eGysoaAj9eEALw_wcB
All the reviews are 5 star and people say it's a great lift. Whatcha think?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Idk man, that looks kinda sketchy to me, I wouldn't put my truck on it. I've never known anyone who had one so I can't say for sure, but I'd be surprised if it really deserved all those good reviews.
I think you should just check with the city and get a real one honestly
FireTruck1984
Michigan
Ted
1984 and 1984
Nationwide 2 Post.. under $2,000
TX87R10
Txr10
R10
I would never get under that (don't 2 posts come with locks to prevent hydraulic pressure loss? Maybe this one does too :shrug:)
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
https://www.harborfreight.com/6000-lb-capacity-scissor-lift-91315.html?cid=paid_google|*PLA+-+Top+SKUs+-+All+(Main)|Shop+Press|91315&utm_source=google&utm_medium=cpc&utm_campaign=*PLA+-+Top+SKUs+-+All+(Main)&utm_content=Shop+Press&gclid=Cj0KCQjw7pKFBhDUARIsAFUoMDZuO1BFP7aEIS0Ekklp1kK-zk_Mb93BHKYUr056wTBK-BbqQ9eGysoaAj9eEALw_wcB
No fricken way my ass would slide under that!!!!! Looks like it could be very unstable to me but JMO!!:smoke2: Select carefully my friend, your life could depend on it!!!!!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
That 2 post **** just scares me.... my buddy has one, (not HF brand), same **** the burb fell off...
I'd feel safer with one that supports the frame alot more than 4 little pucks contacting the frame.
I had a hydraulic ram on a HF engine lift blow out on me...their quality admittedly has went up since then however.
Im watching their game, they're buying out all the big boy brand's customers.
Mac and snap on, and everyone else isnt the same as they once were, they've became greedy in their prices, you're paying for the brand. hf is a bunch hungry mf's looking for business.
I dont exactly trust HF with my life, but if we're talking everyday use tools, sure.
The two posts are fine, but you need to remember that you will likely be into a setup like that(even on the side of the house) for about the same cost for the foundation and concrete work as the cost of the lift itself. You need to have extra reinforcing and anchors placed for a lift like that. It will likely even be MORE expensive to have to add the correct foundation to existing concrete than it would be to pour a purpose built pad.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
that scissor lift looks scary as hell (unstable) and there's no way you can pull a transmission or t case with it. I would go with the 2 post myself Used them for many years with no problems
WFO
Texas Panhandle
My buddy has a 2 post that's very stable.
A few times I've seen his son's big diesel box van up on it.
But, they built their shop with the lift in mind. That bay has a 6" slab, with 4' deep, 24" diameter bellbottomed piers directly under the 2 posts.
Auburn, Washington
Yeah scissor lift = scary, especially coming from the mfg who bought you failing jack stands!
OP, if concerned about mobility, the small 4 post lifts/vehicle stackers are pretty handy, and mobile. Cost wise, can get a decent one for between $1500-2000. Can add a wheel kit to move it around by hand and a jack tray to lift one end of the vehicle. That adds another $500 or so, but makes it portable and you can still pull wheels off of your vehicle.
RecklessWOT
New Hampshire
Kevin
I bought a used one just like you describe for $700-800 about 6 months ago. I love it. Sure not the best for doing suspension work and whatnot but other than that I love it. I don't have the wheels on mine because I have nowhere to move it to as it lives in my 2 car garage, but when I build the bigger building I probably will put it on casters
Poppy 87
Bloomingdale GA
R10 Silverado
Having been in the automotive "stealership" world the last 20ish years, all we had were 2 post lifts. the brand was Rotary, which is a high end brand. I'm currently shopping for one to put in my newly constructed building and am about 98% certain that the brand I will purchase will be Atlas. A 9000lb lift is $2500ish
dhenderz
Michigan
Dennis
I have a Bendpak 10,000lbs 2 post lift in my shop. Love it. You do need to be very careful about what you buy. There are a number of good brands. But there twice as many cheapo ones. Watch the videos Bendpak has on their web site comparing the structural integrity of their lift v the cheap ones.
Frankly it is not the hydraulics that you need to be worried about. The hydraulics will either lift the rated load or they won't - or it will come down to speed of the lift. Once you have the truck in the air you let the cylinders down onto the mechanical safety locks. You never go under a lifted vehicle depending only on the hydraulics holding the load.
What you need to worry about is the structural integrity of the metal parts of the lift, like the arms and posts. You want the peace of mind to know that all of the metal is of the proper spec and thickness, and everything is welded properly.
I have put my Silverado 2500HD 4x4 crew cab diesel up in the air with my Bendpak. It is solid as a rock. But stepping under that truck when its 6 feet in the air will give you pause for a moment as you contemplate whether you bought the high quality lift or the cheapo one, trust me!
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
I own this one: https://www.gregsmithequipment.com/Atlas-OH-10X-EXTRA-WIDE-EXTRA-TALL
I use the crap out of it. It is stable for 2500 trucks but if you're going to go any bigger then that get a 12k. I even stabilize the 2500s with post jacks if I'm going to be doing heavy work like an engine or trans.
Make no mistake, the Chinese lifts are not the same quality as a Rotary or Challenger, but they don't carry the same price tag either. I'd have gotten a Rotary myself but the Atlas goes up higher, and I'm 6'5", so that made the difference for me.
Catbox
Peter
C20 Silverado Camper Special
I see these used in the VW world as those are light cars compared to a full size truck.
Still not good for anything under the truck.
The VW's can get around that as they have a flat floor pan and most of the stuff you need to deal with is on the perimeter of the vehicle.
wkingrey0001
