Lift size?
You should be able to go 35x12.50x15 on 10" wide wheels and be fine on a 4" lift.
Based on personal experience, this would be very iffy. Maybe if it's a truck with stiff springs, tires that are undersized off-brand, and never leaves the street.
Skweegle89
Oklahoma
I would stay with the 6 of you want to keep your 35s. I'm surprised that big ass bumper doesn't smooth out your ride some.
MadOgre
NA
NA
NA
NA
NA
When I pulled the diesel out of mine the front of my truck lifted up almost 3" with Superlift 6" springs specifically for diesels. I had to let the air out of my tires to get the old diesel over the rad support.
It went back down about 1 1/2" with the new small block I put back in.
Also the diesel rad weighs 3 times what a 4 core gas one does and holds double the coolant.
The diesel a/c compressor is no light weight either
There is a lot of weight upfront with the diesels that you cant replace unless using a big block and or adding metal as weights.
I was thinking of using 1" steel plate to build a winch box with. That ought add some weight lol
But I think it works better with the weight directly over the springs and front axle.
MadOgre
NA
NA
NA
NA
NA
Yep your right Andy. The moment you go off road you will have bent fenders from those tires on only 4" of lift.
Jcoleman
Louisiana
My neighbor has a sm465 and np205 that are mated together that he offered to sell me the other day. I can find out what he wants for it if your interested. Would be a little road trip to come get it though.
Possibly but I'm pretty sure it doesn't have the sm465 in it. The transmission that came in it didn't come in very many and doesn't have any pulling power at all. I believe the shift pattern is:
Reverse top left
1st is up
2nd is Directly down from 1st
3rd all the way up and right
I believe third on the shift know says OD
Jcoleman
Louisiana
Yeah I don't care to much for the bumper but I like the idea of having a winch (even tho the one on it is gutless) I would like to mount a hidden one on there. But the front doesn't ride bad it the back end bouncing up and down. I recently found that the shock bushings are gone. Now I just need to decide on buying new shocks and hoping that makes a difference or getting springs then the correct shock sizes to match them. Would like to keep the height in the rear but would love it to not nose dive as much
beest
indiana
matt
You could get a off road design shackle flip kit and use longer rear springs out of a newer truck. That would smooth the ride some. That would also eliminate the rear blocks.
jimlayhee
