Lift Kit Questions, please help
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I was going to make my own mounting pads that will replace the Plate on top of the leaves that the U bolts strap to the axle.
I'd like to see what you come up with. The bottom mount has a little more complex shape to it but could be fabbed up with the required lift. I'm assuming you would weld flat pieces of steel into the U-shape as opposed to bending a single piece?
I was thinking the upper section would be easier since you only have to bridge the gap between the top mount and the plate on the bag. Both being flat surfaces, something as simple as a 4" x 6" section of rectangular tube steel would work...but might look like a redneck/ghetto hack job.
Attached pic for clarity:
picture.php
Driver4r
Nebraska
Trevor
k10,c20
picture.php
I was planning on remaking those U Plates, We have a metal press at school with a bender on one of the sides.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Must be one hell of a machine. That's some thick steel and it's gonna put up a fight.
This is the reason I'm still running blocks in the back, I haven't come up with a professional looking way to add a shackle flip and retain the air bags.
Driver4r
Nebraska
Trevor
k10,c20
i think its like 55ton??
Its Electric pumped Hydrolic. We have bent 3/8ths on it befor just to test it.
This is like ours.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Nice! Watch your fingers around that thing :eek:
Driver4r
Nebraska
Trevor
k10,c20
Scorpion
Denver, Co
I used the ORD shackle flip kit and my rear axle was moved forward. I used a pair of ZRs to move it back the full 1.5". The difference is really noticable in these two pics...
attachment.php
I'm gonna have to measure. Never noticed but don't have a pic (nor have seen mine) from that far back. Guess I can't say for sure now but I'll find out.
jdishman2355
