84 S15 Jimmy 4x4
- Jan 31, 2022
- Boston, Massachusetts
- Adam
- S15 Jimmy
- 2.8L V6
Good afternoon,
Normally I wouldn't ask for your time with something this small. However, I'm driving 21 hours across the country in 5 days and realistically only have two days where I could work on it, so here I am.
Today my left turn signal stopped working. The right one works fine. The high beam light on the dash does not come on, so I assume it doesn't work either. When I use the left turn signal or turn my headlights on, the left dash light stays on, and the front and back external turn lights also come and stay on. Note that when I turn the hazards on, the dash lights blink appropriately, and so do the external lights for the most part. Specifically, the running light and the side marker light are supposed to alternate; however, on the left side, they work simultaneously. I have a video of this below to show what I mean:
So yeah, it's not an issue with the bulbs because they can all light up. The flasher works fine for the right side so I assume that is also fine, however, obviously doesn't do anything for the left side. I was reading the shop manual for this truck and both the turn signal and high beam issues point to a short-to-ground. This would mean that there is unexposed wire making contact with the body somewhere, right? If you guys think this is the most likely issue, how would you go about finding this, and once I find it can I just duct tape it or something?
I truly know nothing when it comes to electrical so any and all feedback is appreciated, just note that I'm on a time crunch! If I can't get this resolved it is not the end of the world, I could just manually move the stock up and down to simulate the flashing but I'd rather not have to worry about stuff like that on my road trip.
Thanks,
Adam
Thanks,
Adam
