Left side vent tube.
73c20jim
Tombstone, AZ
How the hell do you snake this hard plastic vent tube past the steering setup. This sends air to the extreme left air outlet.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I kept telling myself, it came out so damn easy...lots of cussing and three beers got mine back in. It don't even make sense.
73c20jim
Tombstone, AZ
Can it be installed with all thr other vent tubes in place or does it have to be the first tube installed?
It can be finagled in there. It's just frustrating and you have to hold your tounge right.
donnieray
Roanoke Rapids NC
Donnie
350,355;350.
It was the only piece of duct I had removed that day, I seriously considered cutting it in two pieces.
73c20jim
Tombstone, AZ
Craig 85
Nashville, TN
454/TH-400/NP205
I always found you slide it towards the center of the truck first, then up to the left vent. My plastic was still flexible so it made it easier as you will have to bend the driver's side tube to get it past the left vent.
73c20jim
Tombstone, AZ
Flexible???
This is a 46 year old OEM piece from my parts truck. I'm almost afraid to touch it lest it disintegrate.
goodwrenchca
