Left blinker not working when headlights are on.
8GMC6
Fairfax Virginia
Nancy
K2500
Hello all! I recently purchased a 86 GMC K2500 to work on and learn more about vehicles. With that being said I really don’t know much about how to fix electrical issues. Here is my problem…
My blinkers work normally during the day but once I turn on my headlights my left blinker doesn’t work and my right blinker works very slowly.
fast 99
Spokane, Washington
Could be voltage or lack thereof, grounds or flasher itself.
Wallace6
Wyoming
Ray
Suburban
I Had the same problem and the front bulbs fixed it. Good luck
Make sure someone didn't put single filament bulbs into dual element sockets.
Wallace6
Wyoming
Ray
Suburban
It actually ended up being a slightly bad ground
sidschev
Arkansas
sidney
c1500
did you add some blinker fluid
roger0080
Minnesota
If you're in the rust belt, this would be common on my 72's and I finally soldered a ground wire onto the socket itself and ground that wire on all my signals and have not had a problem since. HTH.
Troyport
