Leaking power steering fluid from Hydra boost unit.
racefab57
Burlington, North Carolina
c-30
Hi have a 85 C-30 , looked under truck and have PS fluid under it at the Hydra-Boost unit.. Also have had big section of Master cylinder is low slightly.... Have added twice to it over last couple of months..Truck has been sitting thru out the winter . Is it a big deal to change Boost unit and what unit is best to buy with all the China JUNK out there ???? Help.Thanks DR.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
(Get quality name brand)sounds like your master cylinder needs replaced and also hydroboost. The brake fluid leak probably agitated the hydroboost seal. The hydroboost unit is pretty expensive to replace, you could probably get a seal kit for around 20 bucks and replace that front seal when you're changing master cylinder. I think there's a snap ring behind there.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Sounds like you should change the master cylinder and the hydro boost unit. I helped Dad replace the vacuum booster on our '90 R2500 Burb, was a good bit of work but it's easier to do with two people (one in the cab and one under the hood). When the hydro boost unit went out on my OBS Crew Cab, I had it done at a shop. Took them several hours.
racefab57
c-30
Any one know of a hydra-Boost rebuilder? With the parts supplies available for do it yourselfers( AK part houses)... I dont know if parts would be any good...Cardone is the only one available to my good parts guys place I go. AND that's not happening...Need some help here, Thanks much. DR.
fast 99
Spokane, Washington
I used a local rebuilder for HB units. However, ones that had a staked push rod on the brake pedal side could not be rebuilt. Apparently it could not be disassembled. Rock auto and NAPA have rebuilt units and appears to be the only option.
Will caution you, there is an accumulator can with residual pressure and a serious spring. Unless you know EXACTLY how to rebuild it safely...........don't touch it.
aaron hunsberger
