Leaking fuel
jonbgood
east bay area , California
Johnny
1977 gmc c25
fuel is leaking out from this capped off spot. Is this supposed to be connected to anywhere? Also what’s the proper connection for this tube on valve cover? Heavy fuel and exhaust smell while driving, trying to properly connect it all back together . Thanks
Strick
Dunn, NC
Harold
C20 Crew
The crankcase vent is supposed to be routed back to the air cleaner. No fuel is supposed to come from any of the vacuum ports on the carb either.
jonbgood
Johnny
Do you know why it would be coming out of there? Is that vacuum port supposed to be connected anywhere?
Strick
Dunn, NC
Harold
C20 Crew
That is supposed to be hooked to the charcoal canister I do believe. Maybe some fuel vapor but not liquid fuel exiting.
HS
Most likely float level is too high,maybe float is heavy,. Carbureator looks new my 1st guess is not put together correctly from the factory. Do not attach it to the charcoal cannister now,connect it after the problem is corrected. Fuel in the cannister ruins it.
fast 99
Spokane, Washington
Bottom picture finger is pointing at breather. Loops back around into the square hole in air cleaner. Breather filter is missing also needs clip to attach it to air cleaner, sometimes included with filter. Drivers side valve cover should have the PCV valve.
Carb'ed Vortec 350
1977 gmc c25
That carburetor looks like one of those new chinesium quadrajets. From my reading on those, no good. If there's a warranty, return it for a full refund and buy a rebuilt original that fits your application.
Carb'ed Vortec 350
Because it's a chinesium carburetor. They look great. That's all. Pure junk
jonbgood
Johnny
Yea I removed it tonight, it has no numbers or identification.
jonbgood
Johnny
Yea I got it off, probably just going to junk it. Came with truck when I recently purchased. It has no markings on it just a generic Chinese carb I guess
82jimmy
