Leaf spring bushing destroyed. What would cause this?
RanchWelder
Earth
Blazer
350ci
Figured as much...
Appreciate the heads up... starting to figure it out...
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I was told not to lube bushings with petroleum grease, but that was with rubber bushings. The petroleum grease softens rubber causing them to split and turn to mush, but I didn't know if it would do that to poly.
Rubber I'm pretty sure you're good to use anti seize. You're correct though; and as far as I know poly is oil resistant to an extent.
Figured as much...
Damn!!! Lol. I'll bet that was violent in the cab.
  • Like
Reactions: WFO
WFO
Texas Panhandle
I reckon!
If he would've slowed down a touch and not over jumped it, it wouldn't have been too bad.
seanhatesregister
