Leaf Spring/Axle/Frame
SMC2224
Indiana
Skyler
K30 Crew Cab
So I got a D60, my frame mounts ready, and brand new front leaf springs for the front of my 77 K30. What should be the order of installation? Should I attach the leafs to the axle and torque u bolts then lift up to frame? Or should I attach leafs to frame and then lift up axle? Does it not matter? Final torque on u bolts should be after wheels are on ground right? Thanks
RanchWelder
Earth
Blazer
355ci
Here's a video regarding spring and bushing installation mistakes:
Congrats on the D60!
Subscribed.
I'll bet there's a secret to getting it all lined up and very close to straight the first time.
Pics?
Install the springs first. Then the axle. You can torque the u-bolts before the suspension is loaded, if that makes it easier for you. Then torque the spring eye bolts with weight on the front end. Re-torque the u-bolts after 100 miles or so.
sqrbdy
