tdub209
- Aug 14, 2015
- Tracy, CA
- TJ
- k20
So i just finished my 6" lift on my k20. I went with the rough country kit, but blocks in the rear... didn't have the money saved for leafs at the moment so just got blocks for the time being till i buy ez-ride springs from tuff country most likely. My pinion angles aren't terrible with the transfer case drop bracket, but axle still isn't perfect and at a slight angle. plus running a 4" block is not my favorite thing in the world.
With that said is anyone running ladder bars or traction bars?
if so from what company?
who builds the custom ones?
I seen tuff country makes ladder bars and traction bars for the 73-91 squares, but haven't heard anything or seen any feed back on them? does anyone run them or know anything about them? both kits look easy to install and require no welding. so that caught my eye since i really don't want to start welding on this axle if i end up getting a new one.
the ladder bar mounts in between the u-bolts and axle then the other end frame mount has to be drilled and bolted down. looks solid.
the traction bars mount in between the leaf spring and u-bolt then the other end you drill a hole in the leaf spring frame perch and the stud would slide through then bolt there. that one seems kinda sketchier being just one stuff going through the perch, if you make power or have axle wrap before you would think it would bend that perch eventually?
so personally i was leaning toward the ladder bar, but haven't heard anything so was looking for input on them or if anyone has any other ideas?
But yes 6" leafs are my next suspension part for the rear lol.
thanks guys and happy new year [emoji323]
-Tdub209
1985 K20 w/ a cammed, ported, and bored 350, sm465, np208, 4.10 gears, dana 60 & corp 14, 6" lift, 37s, and a full stereo.
-Tdub209
