K5 K10 17x8 or 17x9 vision Cheyenne Aluminum rally wheels?
Auburn, Washington
These are a new offering within the past year from what I can gather. The few wheels I can find used that have a center bore that the 4 inch front hubs will clear are either dirt cheap and immediately sold or 10 inch wide which I don’t want or rusty 15” rallies for $400+ firm.
So far they haven’t charged me tax, which would add nearly 8 to 10% to the total price.
I like the Mag slots, but they are a lot more expensive.
I know they’re a fairly recent offering. Didn’t exist when I was looking for wheels for the K20 a few years Ago. I’d assume they’re fairly popular and seem like a great value for what they are.
Especially compared to the us mags expensive and really expensive options. Cheaper than equivalent steel rally’s too.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Got an email from them. The 17x8 wheel 0 offset are on 60+ day back order. They offered the 17x9 wheel but -12mm offset is in stock. Hmmm…
Rustisbest
Tennessee
6.1762844 liters
I'm sure these are the same and just a center cap sticker change made for Summit. They're showing in stock too
As far as cost, you cant beat em at that price. I spent $300 EACH on 2 15x10 rallys about a year ago from Wheel Vintiques. I could've bought a whole new set of 4 for a little more $$$ and saved close to 25 lbs of rotating weight-but these weren't out then.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
I’m just going to wait for the 17x8 0 offset. The 17x9 -12 mm would probably be fine but I like the look of 285/70R17 on 8” wheel. Don’t think the 9” would look bro-dozer wide but the front tires already stick out from the fenders with my current 8” wide wheels. I’ve thought about adding wheel spacers to the rear since those are so tucked in but have heard to avoid wheel spacers.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Found a too good to pass up deal on some used BFG KM3 mud terrains. At 67lbs per tire I’ll need all the weight savings of the aluminum wheels. Will see how the 305 responds to them going from 31.5 10.5 R15 + steel wheels. Gear ratio is 3:73 and 700R4 has that nice low first gear compared to my 79 k10 with the th350 but I have double the hp and tq in that truck with the new blueprint400.
If it's an original, these K series rigs came from the factory with a LOT of positive Camber......like 1 to 1 1/2 degrees! A common gripe was "my tires are wearing" and ALWAYS on the outsides! These solid axles were also pretty damn stout, they didn't bend unless Colt Siever was driving them! I saw this weekly, if not daily, when I was the "Alignment Technician" a the the local Chev-Cad dealership from 1969 to 1980. It's true toe is the most severe wear angle when wrong, but the Camber will do it also if left alone!
One thing that I have noticed is that for some reason, the stock size tires will tend to wear on the outside shoulder, but larger tires don't seem to. It must have something to do with the added forgiveness of a taller sidewall?
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Guessing I may need extended lug nuts for these wheels. Can’t find a spec on how thick they are… The method level 8 wheels on my ‘79 k10 required extended nuts for a safe amount threaded stud engagement. 7/16-20 correct? ‘86 k5 blazer.
I may go black Lugnuts instead of chrome.
Black only offered in shorter length
Chrome
TDoc
Flagstaff, Arizona
Terrell
K10, K5
They cancelled my order due to not knowing when they will be restocking the 17x8
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
If you get them please share some photos, I really like the stock rally rim look but wanted to run Wilwood brakes on all four wheels. Large rims then the stock 15s would make that possible.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Found these 16x9 wheels locally. Guy will take $250 for the set but said I need to run a 3/16 spacer up front to clear drag link. What do you all think?
I have some 285/75/16 k02 load range E I would have mounted. BFG says they can fit 7.5-9” rims.
American Racing AR62 Outlaw II
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Or these 16x8 American racing AR172 $200
A bit beat up around the lugs and some dings in the face.
I believe those are 15"x8" and the seller does not know how to properly measure wheels.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Winner, winner, chicken dinner! Guy showed up and I checked the stamp on the inside 15x8.5. Looks like I’m going with the AR172 16x8 wheels.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
The K5 got the Discount tire 16” wheels and tires from my k10 and the k10 got the AR172 16” wheels and tires. Both are 285/75/16 about 32.8” tire.
verbalist54
