k5 floor panels
RoryH19
Rory
R10 Silverado SWB
It's time to start working on my K5 floors.
Any suggestions of companies to use; Goodmark, AMD, Sherman?
I have to replace the front seat and rear seat floor along with the inner rocker (I think).
The outer rocker looks good but may have to come off for the other panels to be replaced.
Also this because the previous owner had a leak in the right topper window that ran down and stayed in the carpet.
In this link I guess I would use number 4 and 8 plus the inner and probably outer rockers?
Can the drop in floors be used or is that suburban?
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=12
Anything to look out for, suggestions?
Thanks.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I have bought from LMC, classic, rock auto, ebay, AMD. All are basically the same. Metal thickness is within 0.001" of oe metal. A difference that you will not see in welding. If you need to do the inner rockers but if your outer rockers are still good you can replace the inners without taking the outers off. I would say go with whatever is the best deal at the time of purchase.
RoryH19
Rory
R10 Silverado SWB
Good to know, shipping seems to be the worst part of the purchase.
I have a Summit racing close to me that I will try to get the panels from.
Yes I would like to keep my original outer rockers if possible. Hopefully I can. Just depends what I run into when cutting the old out.
This thread has been moved out of "Site News" and into a more appropriate subforum.
nobodyawesome
