Just picked up an LT4 swapped '86 C10
F51 LRS
SC
Joe
LT4 350
Hey y'all, I just picked up a new to me '86 C10 Silverado with a '96 LT4 swap. Working through some issues with it, but the intent is to daily drive it so I can sell my newer truck & get rid of any car payments! Working on tracking down why I experienced massive oil loss (2 quarts in ~250 miles) without seeing or smelling burning oil. The front of the engine was wet so put new timing cover gaskets/seals in. Hopefully that helps.
Next up is fixing the amateur hour wiring job one of the previous owners did (i.e. turn signals only work when headlights are off). Anyway, glad to be here & I expect I'll be spending an inordinate amount of time on the forum as I work through everything.
1lejohn
texas
john
k-1500, 2500 HD
Welcome. Clean looking truck.
WFO
Texas Panhandle
animal
Lee
c10 silverado
350ish
:welcome:
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
:welcome:
Howdy from Ohio!
The LT4 swap is cool! That's not something that's common anymore at all. When I read the title, I assumed it was going to be a modern LT4 lol.
F51 LRS
SC
Joe
LT4 350
Howdy from Ohio!
The LT4 is one of the reasons I was attracted to this one - not to mention he already did the 5/7 drop and wheels which saved me the hassle and expense :D
There's nothing quite like a sbc with flowmasters; having a little hot rod under the hood is also nice.
Welcome from Oregon!
The turn signal issue is most likely going to be broken or bad grounds at either the harness ends or the light sockets themselves. I've had this issue on two different squares and in one case it was a bad ground connection at the rear right turn signal plug socket and the other one was a bad ground wire connection at the front marker light socket. They will work OK or maybe a little slow without the headlights on because it is a very small load needing to dissipate through the ground. Once the marker lights come on with the headlights, the bad ground connection gets overwhelmed and you end up with no current flow to actuate the turn signal flasher so the turn signal just stays locked on. I would go through and make sure all the big ground connections are clean and secure, then start going around to each light connector and check for continuity between the ground pin for the light and the battery on each socket. I bet you find one or more socket with a really high resistance or even an open ground circuit.
Doolin
