JB3 vs JB5
mrnapolean1
'87
R10
4.3 V6
Whats the difference between JB3 and JB5?
Im needing front rotors and autozone calls for two different kinds: JB3 and JB5.
IIRC, the difference is the thickness of the rotors. JB5 is .25 thicker to the best of my knowledge. As far as diameter, I think they are the same and also use the same pads.
Maybe someone else can confirm. :shrug:
For purpose of getting parts, you should be able to measure the diameter of the rotor and the thickness. Of course the thickness could be off a bit due to being turned, but you should still be able to figure out if you have a 1 in or 1.25 in thick rotor.
OSReaper
