RanchWelder
- Jan 14, 2023
- Earth
- Blazer
- 350ci
oldretiredafguy is on to something...
Maybe... it's time to add an amplifier?
Stick a 2Mf Cap and a 2000W pair of subs in that sweetie.
With those Bad Azz wheels, your truck should be heard from 3 blocks away... minimum.
You'll need a loud alarm... Then your neighbors can enjoy the electrical symphony every night too!
My advice is to ditch the Buzzer. It's a liar... Your better off wiring in a SIRI and program it to bitch at you every time you open the door...
"Why are you late... every damn morning!"
"Get those filthy boots out of the truck NOW!"
"Are you shiztFaced again?"
"You don't need your turn signal! Those are for idiots!"
"Seatbelt! Seatbelt! Seatbelt!..." Leave this one on until you ground your belt. Wire every ground in the truck to your seatbelt clasp.
Then you'll know it's good. Then switch voices from Siri to Gunnery Sgt. Hartman...
There ain't no stray voltages or bad grounds after all the work you've done...
You won't want to complain to anyone after a few months of Ermey...
