Interior Trim Guidance
Scott Delaney
Joliet
Scott
6.2L Detroit Diesel
I have a 1983 C20 Custom Deluxe which came basic with no interior molding, headliner, etc.
My question is how I go about installing these in a truck that never had them before. I would imagine there's some way to get everything lined up so it fits correctly.
All the videos and how-to's I can find all deal with replacing old mouldings with new.
Any guidance, links to videos, articles, whatever would be greatly appreciated.
Thanks
Thanks.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I bought the headliner "Kit" from LMC, the kit includes a few pieces of fleece upholstered cardboard trim and some velcro to mount the headliner.
The included trim was ridiculous, it would probably work but was very cheesy. I ended up ordering all new factory type trim which cost more than the headliner kit itself.
seven13stvn
Houston
Steven
Custom Deluxe
Have this same question.
Rickf
Grafton NH
1974, 1954 & a 1937
If it was my project, I'd try a salvage yard first for the parts and hardware.
Scott91370
Burleson, Tx
Scott
Sierra1500
Lining it up will take some (quite a bit) of measuring. I would go to a couple of car meets, talk to a few people and see if they would let you measure where everything is. Take a bunch of pictures them mock it up in your truck. Use some blue painters tape to secure everything. Then when it is in the right place...zip your screws in.
tater dog
tater
k30
i would get used from a donor truck that way you know they'll fit right . . tricky part is lining up where to drill your holes for the trim screws . shouldn't be as bad in your single cab but id get a buddy to help hold up the trim and headliner while you line it all up .
FireTruck1984
Michigan
1984 and 1984
I recently did this exact job on a single cab that originally had no trim or headliner. I bought all the trim through LMC (good quality-Good fit)
After headliner was in place I one by one held and taped each trim piece in place while I drilled for trim screws (two different length screws for different pieces) careful to drill perpendicular to the trim face so the screw heads seat correctly, I did redo a couple of drill holes for that reason. Fairly easy..Good luck !
BrianBaca
