intake Manifolds
would you run edelbrock or holley?
  • edelbrock
    Votes: 40 74.1%
  • holley
    Votes: 14 25.9%
  • Total voters
    54
79K10
Sacramento,ca
Ryan
350/th350
im lucky, i only have to drive 2 miles to work and 7 miles to take my kids to school, not too worried about MPG at the moment lol... might look into a qjet, throttle response is always a plus
350runner
tx
Ceasar
i hear a lot of people talking about the Qjets, are they really better than an edelbrock or holley if you get em dialed in? i dont think they look that cool, and i want my motor to look cool lol
The difference is night and day.
MadOgre
NA
NA
NA
NA
NA
A good quadjet will out perform an Edelbrock any day and as a daily driver the holley too. The problem is getting your qaudjet into top shape. If the throttle shaft bushings and fuel well plugs are not rebuilt properly or the body is severely warped they wont work very well no matter who does the work or how shiny they look.
The quadjet performs consistently and well at all throttle stages and in off camber situations as well.
But yes for our trucks the Qaudjet is king of all carburetors for our applications. In fact a quadjet can be modified for race applications too and performs quite well. Up to 850 cfm requirements.
79K10
Sacramento,ca
Ryan
350/th350
I'm cleaning out my holley, first time for everything lol ... Found some grass in the needle valve and
jet ...
Lol
Seems easy enough I guess... Only small problem was getting the metering blocks off
79K10
Sacramento,ca
Ryan
350/th350
All back together and cleaned out. New power valve 6.5, new accel pump diaphragm, new gaskets, grass removed and 99% if the caked on gasket removed
Hoping to fire it tomorrow
cfieldchevy
Maryland
George
Had a 600 edelbrock on my hotrod. When I swapped to a 600 holley dbl pumper i had better throttle response and a bit more power. Of course it wakes up around 2500, 3000 rpm. I put the edelbrock on my k20 and it runs very well. Good torque with edel perf intake. Brodix intake on hotrod.
cfieldchevy
Maryland
George
I like the valve covers they are similar to mine on my car
79K10
Sacramento,ca
Ryan
350/th350
Fired right up when I turned the key! I was pretty happy till the rockers started making a racket, guess the valve covers are coming off again... Time for some old school tighten till til stops ticking then 1/2 more lol
350runner
tx
Ceasar
lol
cfieldchevy
Maryland
George
I had to grind a bit off the inside of my covers on the ends. They hit my rocker stabilizer bars.
79K10
Sacramento,ca
Ryan
350/th350
It didn't make this much noise before, I don't even want to fire it up till I get the cover off and tighten at least 2 that are really loud
cfieldchevy
Maryland
George
So youve got hydr lifters. Mine tick all over- mech lifters
cfieldchevy
Maryland
George
Make sure theyre getting oil
79K10
Sacramento,ca
Ryan
350/th350
I'll pull the covers this weekend... I've heard they can be noisy, but the sound they're making doesn't make me feel good at all, sounds like they are way too loose to me.
I'll make sure it's getting oil, I really don't wanna pull the intake manifold off! Blowing out the rods is about as far as I want to get into it lol
cfieldchevy
Maryland
George
Are they stock stamped or roller rockers?
brad083
