Installing a new automatic choke on verajet carb?
LilRobert1367
Colorado
Robert
How do I install a new automatic choke on a verajet carb? Is there a process I need to do before just screwing the automatic choke on the carb
ali_c20
Austria
Alexander
C20, K5
You mean electric choke conversion ?
Install the heated spring element, adjust it. Check that linkage is moving freely. Plug the heat pipe inlet at the choke housing otherwise you create a vacuum leak.
If I forgot something more knowledgeable members will chime in.
Carb manuals:
https://www.carburetor-parts.com/carburetor-repair-manuals
Is this on a v6 or i4? Do you mean varajet (I or II)
ali_c20
Austria
Alexander
C20, K5
dowork69
