t44e6
- Dec 23, 2021
- NH USA
- David
- K10
Ordered a complete set of hinges and trunnions from LMC trucks, the originals on my 82 were worn and on the left side the weld between the cup and the base had broken loose. They seem to be well made. The bolt holes on the "hinge" portion that bolts to the taligate itself had undersized mounting holes instead of the 3/8" holes of the original. It only took a few minutes to drill them out, but it was a reminder that when you buy reproduction parts you may need to do some fitting! Have any of you run into a similar issue? Does your truck have 2 different sizes of fasteners? GM does likes to use multiple sizes on one assembly but I think this is just a QC issue. Tailgate is held much more securely when latched now, and aside from that issue they function as they should. As always a soaking with Kroil ahead of time made it easier to remove the mounting hardware and running the bolts through a thread cleaning die and applying a dab of anti-seize made reassembly a breeze.
