PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- 84,79,77,76,70,48
- Suburban k10, bonanza k10, k30, k20, c10, gmc 1/2ton
- 350, 350, 350, 350, 350, 350
The fronts are always cold, not matter how far I drive, unless I'm heavy braking. The fronts are fine. I don't have a visual Ir gun, I've just got one of those laser temp guns.I've also seen where the rod under the dash was adjusted out to far, and caused drag issues similar to yours but that usually only happens after someone has messed with it.
It would be helpful if you had a IR heat gun and could take temps of each wheel when the symptoms are occurring, I'm just throwing that idea out there if you do have one.
No matter what the cause of the drag is once the shoes or pads if it were the fronts (not saying it is being hypothetical) heat up the rotors or drums the metal expands and the drag increase exponentially. Also if something is acting like a check valve (a bad hose) as others have indicated. Generally a bad hardline will leak, but if a hardline is crimped or bent it can sometimes cause a restriction.
Is it just one drum or both dragging. Also it would be good if you could tell if the fronts are dragging even if only slightly. Lets face it if it's all 4 involved, that could really narrow down your search.
Even if you think the play is enough in the pedal you could try adding a bit more as something free to try.
Both drums are dragging but one gets hotter than the other. Much faster as well. Doesn't matter the adjustment. The axle hard lines are new and I haven't touched the other hardlines since I did my hoses, but they look completely fine.
